Date/Time: Sun, 12 Jan 2025 08:09:46 +0000
Advanced studies - is it possible to detect the time and price of an existing chart drawing?
View Count: 830
[2017-02-07 20:07:44]
User99606 - Posts: 9
I'd like to trigger a trade when price intersects a ray that I've drawn on the chart and understand that this will require some programming to achieve. I am not asking for programming help beyond figuring out if what I want to do is even possible.
From what I can see from looking at the programming guide, the capabilities are there to have the study actually draw a ray, but I don't see anything that would allow my code to determine the time and price values of an existing ray.
Two questions:
Is it possible to code a study that can access an existing chart drawing's time and price value?
If not, is it possible for a custom study to allow me to create a chart drawing the same way I do with a normal drawing tool, or do I have to enter specific values in a dialog box to have the code draw the ray?
Thank you.
Date Time Of Last Edit: 2017-02-07 20:09:11
[2017-02-08 04:08:36]
You need to use this function to get a user drawn chart drawing:
Using Drawing Tools From an Advanced Custom Study: sc.GetUserDrawnChartDrawing()
To use drawing tools from an advanced custom study, refer to:
