Date/Time: Sun, 12 Jan 2025 07:57:21 +0000
newer build issues ?
View Count: 674
[2017-02-07 14:28:01]
User20450 - Posts: 330
any reason when opening more then once chartbook in 1510 and over i get spinning and sierra just goes to zero on cpu and i have to restart ?
image2017-02-07_09-25.jpg / V - Attached On 2017-02-07 14:27:22 UTC - Size: 4.88 KB - 220 views
[2017-02-07 17:11:59]
Do not use newer versions of Sierra Chart until we determine what the problem is in your case.
Follow the instructions here and go back to version 1506:
http://www.sierrachart.com/index.php?page=doc/download.php#Rollback
Let us know if you still have a problem with that version.
