Date/Time: Sun, 12 Jan 2025 07:57:37 +0000
Volume by price settings do not save
View Count: 610
[2017-02-07 12:20:56] |
User11010 - Posts: 7 |
Have Version 1510 Re VbP After altering the settings and pressing the default box then apply and OK the settings do not save and The Volume by profile drawing tool will draw the box but no profile is visible in it at all So have been unable to use Sierra and unable to trade. Please advise ASAP |
[2017-02-07 17:55:01] |
This is not completely clear for us. So you are saying when you use the Tools >> Draw Volume Profile tool, that you do not see the drawn Volume Profile? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
