Date/Time: Sun, 12 Jan 2025 07:50:29 +0000
Best Data Provider for SC
View Count: 1544
[2017-02-07 10:59:56] |
User172040 - Posts: 70 |
Hi, I just want to be clear on what you recommend as the best data provider for SC? Is it your realtime and historical exchange data feed for $35pm? Then also I see you charge $35 for 100 real-time symbols. Does that mean on any given day I can choose new 100 symbols? If I want market depth (non pro account) for the whole CME Group then it's $15.75pm in addition to the $35pm? If I prefer to use SC data, would it still be possible to trade through Interactive brokers from the SC charting platform? Many thanks JP Roux |
[2017-02-07 18:17:27] |
Yes this is correct for 100 real-time symbols.100 real-time symbols mean that you can receive real-time data on 100 symbols at a time. You can look at more than that throughout the day. Although only 100 at a time. But when you go over the 100 limit, you need to reconnect to the data feed. If I want market depth (non pro account) for the whole CME Group then it's $15.75pm in addition to the $35pm? Yes as long as you have a funded futures trading account. would it still be possible to trade through Interactive brokers from the SC charting platform? Yes this is answered in detail here:http://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#IntegrationWithTradingServices Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
