Date/Time: Sun, 12 Jan 2025 07:44:00 +0000
How to change the time used in the TPO Charts provided in the Advanced Chartbook Tab
View Count: 666
[2017-02-07 08:12:31] |
sparky36 - Posts: 21 |
Hi, I live in Phoenix, AZ and I wanted to make sure the times used in the 2 TPO charts (Day/Evening Sessions split into 2 Market Profiles and 24 hr Full Market Profile). Which time setting do I need to use so that they are accurate via local Phoenix time. In addition to the Chart Settings time, I believe I need to change settings on the indicators as well. Please let me know what I need to do. TIA |
[2017-02-07 17:34:28] |
Follow the instructions here to set Sierra Chart to use your time zone: http://www.sierrachart.com/index.php?page=doc/TimeZone.html And then follow the instructions here to display separate profiles for both the day and evening sessions in a TPO chart: http://www.sierrachart.com/index.php?page=doc/TPOVolProfileCharts.html#DayEveningSeparateProfiles You will need to set the Session Times including the evening session times for the chart to what you require. Refer to: http://www.sierrachart.com/index.php?page=doc/SessionTimes.php In regards to this, there is nothing to do other than what we explain above: In addition to the Chart Settings time, I believe I need to change settings on the indicators as well.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-02-07 17:38:33
