Date/Time: Sun, 12 Jan 2025 08:02:05 +0000
Renko bars 10 tick reversal bar size?
View Count: 2134
[2017-02-06 23:45:51]
sean mathes - Posts: 10
I am trying to figure out if there is a way to change the renko reversal bar size? For example I am using a 5 tick renko and I want to make the reversal bars 10 ticks? I have enabled the reversal in the Flex Renkos but doesn't seem to change anything. Here is an example of what I am trying to do. Thanks for any suggestions.
imagerenko.png / V - Attached On 2017-02-06 23:45:17 UTC - Size: 51.96 KB - 346 views
[2017-02-07 18:10:05]
This is not supported.
How standard Renko bars and Flex Renko bars work is documented on this page:
http://www.sierrachart.com/index.php?page=doc/RenkoCharts.html
Sierra Chart also has Universal Renko Bars, but those do not do what you want either.
