Date/Time: Sun, 12 Jan 2025 05:30:34 +0000
Drawn Volume Profile Selection
View Count: 1042
[2017-02-05 15:06:47] |
User104854 - Posts: 457 |
Hi. I would like to select a drawn volume profile on my chart by left clicking the outline only. Currently it gets activated when I do that but it also gets activated if I right click anywhere on the profile. I would like to disable activating it when I right click. Can this be done? I've gone to the tool settings and checked activate by outline only. It's the right clicking that I do not want. Thank you. |
[2017-02-05 20:03:32] |
We need to look into this.
