Date/Time: Sun, 12 Jan 2025 05:23:38 +0000
Possible Numbers Bars Bug
View Count: 1004
[2017-02-04 14:55:05]
Guilherme - Posts: 66
Hi. I found out something that should be a bug when numbers bars study identifies the POC (point of control for the bar). I get many situations here where it identifies a level with visible much less volume than other bars. I've attached a Picture showing the problem.
imagebug-numbers-bars.png / V - Attached On 2017-02-04 14:54:37 UTC - Size: 107.39 KB - 263 views
[2017-02-04 21:31:51]
We need to get the Chartbook you are using. Provide the Chartbook with only this single chart in it. Follow these instructions:
[2017-02-05 12:59:21]
Just attached the chartbook.
attachmentbug-volume.cht - Attached On 2017-02-05 12:58:48 UTC - Size: 39.1 KB - 350 views
[2017-02-05 20:32:57]
This Chartbook does not contain the chart image that you posted.
There is no way we can help with this unless you provide us both a chart image and a matching Chartbook demonstrating the issue.
We see no indication of the issue in the Chart you provided.
[2017-02-05 21:55:02]
Here it is. The chartbook, the picture and even the symbol data file.
Date Time Of Last Edit: 2017-02-05 21:56:00
imagebug-sierra-2017-02-05_19-48-07.png / V - Attached On 2017-02-05 21:53:08 UTC - Size: 109.94 KB - 265 views
attachmentbug-volume.cht - Attached On 2017-02-05 21:53:26 UTC - Size: 39.1 KB - 296 views
attachmentDOLH17.scid - Attached On 2017-02-05 21:54:27 UTC - Size: 4.29 MB - 422 views
[2017-02-06 19:46:17]
The problem is on your side with your data.
The point of control is based on the total volume of a price level. You need to set the Numbers Bars text to display Volume and not Bid Volume/Ask Volume.
