Date/Time: Sun, 12 Jan 2025 05:17:45 +0000
[Programming Help] - Multiple Chart Studies
View Count: 805
[2017-02-04 10:33:44]
User53601 - Posts: 105
I am comparing two charts (Up volume and Down Volume) by using Ratio (Bar) study.
If Up volume is higher then Down volume, the ratio is in a range ( 1, infinity).
If Up volume is lower then Down volume, the ratio is in a range (0, 1).
This seems not a symmetrical scale.
I mean, if Up volume is lower, then tie ratio should be in a range ( -infinity, -1 )
I was looking for a solution by using an IF condition, to define two different formulas, for the two cases. However did not find such a possibility,
Could you give an advice, is there a way to relate/compare two charts by using an IF condition.
thank you
