Date/Time: Sun, 12 Jan 2025 05:29:47 +0000
Configuring a Keltner Channels study
View Count: 1839
[2017-02-03 23:40:06] |
tommartin321 - Posts: 74 |
Hello, Attached is a screen shot of the configuration settings for a Keltner Channels study. Can you help me setup the following configuration? A Keltner Channels with 2.25 ARTs around the Exponentiation Moving Average (EMA). Thanks, Tom |
Keltner Channels Configuration.JPG / V - Attached On 2017-02-03 23:37:29 UTC - Size: 82.09 KB - 443 views Attachment Deleted. |
[2017-02-05 02:36:22] |
Set the Top/Bottom Band Multiplier Inputs to 2.25. Set the *Average Length Inputs to what you require. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-02-05 02:36:35
