Date/Time: Sun, 12 Jan 2025 05:12:37 +0000
How to use Zaner and FXCM
View Count: 809
[2017-02-03 20:00:55] |
User904781 - Posts: 1 |
Hi, I started with an account with Zaner, who provides me with your charting platform. They only trade on the futures side. I would like to also trade forex and have opened an account with FXCM. Since I like Sierra's chart and they have started to support your service I have the forex data run to you from them. The challenge is. Do I need a separate, paid account with you or is the Zaner account going to work for both with data service changes? I hope you understand my basic question? I'm not trying to be cheap, just want it to work as seamlessly as possible and still use your platform!! Thanks Steve
[2017-02-04 01:42:55] |
If you want to use FXCM, then you just need to install another copy of Sierra Chart following the instructions here: Using Multiple Data and Trading Services at the Same Time And become set up to use FXCM following the instructions here: https://www.sierrachart.com/index.php?page=doc/FXCMTrading.php#SetupInstructions You do not need another account. You just use the same Sierra Chart account you are using. If you just want to use the cash Forex data, refer to the instructions here: Sierra Chart Real Time and Historical Forex and CFD Data Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
