Date/Time: Sun, 12 Jan 2025 05:39:00 +0000
Two instances - one "Data Files Folder"
View Count: 744
[2017-02-03 15:47:59]
nicktrader - Posts: 727
I am running two instances. Two different broker with the same datafeed "CQG"
The two instances are installed in Folders "SC_A" and "SC_B". Is it possible that both instances use the same "Data Files Folder" i.e.: C:\SC_A\Data\".
Main background is that both instances use same spreadsheet. Each day I write own data manually in the spreadsheet.
[2017-02-03 18:04:06]
No definitely do not do this. You will create problems.
