Date/Time: Sun, 12 Jan 2025 05:38:12 +0000
OutsideBar Problem
View Count: 812
[2017-02-03 11:50:21]
User792126 - Posts: 2
Hi, I'm trying to use spreadsheet study to draw horizontal lines only from Otsidebar created/pointed Candle and and all lines like OHLC and I would also extend these lines until next day or even longer.
Have used spreadsheet study and in cell K3 following formula: =if(aa3>0,b3,0) (Outside bar is seen at column AA)
Spreadsheet seems ok and it can find all the outside bar only open prices , but when I try to plot these into chart at subgraphs K(SG1) nothing is drawn? And if I try to change draw style into OHCL and then apply it will reset back to Candlestick. I have tried to input manually a number into K3 but it does not output anything into chart. Is there something wrong with parameters somewhere?
[2017-02-03 17:58:45]
What is the Graph Draw Type for the spreadsheet study set to? Refer to:
Graph Draw Types
How is this Spreadsheet Study Input set?:
https://www.sierrachart.com/index.php?page=doc/SpreadsheetStudyInputs.html#PriceGraphStyle
What happens when you enter =E3 into cell K3. You should see a single line of the last trade price outputted by the Spreadsheet study on the chart.
[2017-02-04 07:15:01]
Graph Draw type is set for Candlestick and as I mentioned earlier it will be reset into that for some reason.
If I will refer to E3 at cell K3 -nothing will be displayed. If I tick name label then I can see "K" in the main Price Graph.
[2017-02-05 20:43:08]
Make sure this Spreadsheet Study Input is set to No:
Spreadsheet Study Inputs: Use Price Graph Style
Go through the Spreadsheet Study instructions for a basic introduction to use the Spreadsheet Study:
https://www.sierrachart.com/index.php?page=doc/StudiesSystemsAlerts.php#Instructions
Start with a completely new instance of the Spreadsheet Study.
This way you can see how to use it and not have any problems like this.
Date Time Of Last Edit: 2017-02-05 20:45:33
