Date/Time: Sun, 12 Jan 2025 04:28:41 +0000
Type of chart / DOM on chart
View Count: 754
[2017-02-02 16:06:14]
User103296 - Posts: 1
I am a trial user trying to create a chart similar to the one attached.
1. Would like the chart to have the volume at price horizontal bars on either side of a vertical line bar.
2. I would like to see the DOM of the horizontal bar as well.
Please see attached chart for reference.
Thank you
imagesierrachart3.jpg / V - Attached On 2017-02-02 16:05:50 UTC - Size: 99.91 KB - 194 views
[2017-02-02 18:44:35]
1. This can be done with the Numbers Bars study:
http://www.sierrachart.com/index.php?page=doc/NumbersBars.php
You will want to set the Column # Numbers Bars Text Input with the study to Bid Vol x Ask Vol :
http://www.sierrachart.com/index.php?page=doc/NumbersBars.php#TextTypes
You will want to set the Column 1 Background Type Input with the study to Ask/Bid Volume Split Profile:
http://www.sierrachart.com/index.php?page=doc/NumbersBars.php#BackgroundTypes
2. This is not completely clear but here is the information about the DOM Graph:
http://www.sierrachart.com/index.php?page=doc/TradeMenu.html#DrawDOMGraph
