Date/Time: Wed, 02 Jul 2025 06:46:01 +0000
Can't modify Attached MIT target
View Count: 1014
[2017-02-02 15:06:33]
DabbaDo - Posts: 148
Version 1510
I have a simple attached order, with a Stop plus a Target set to Market If Touched.
Once I enter the position, the attached orders show on my chart appropriately.
But when I try to "drag" the target order, it jumps back to its initial position. That is, I an unable to modify the MIT target price once the order is established.
When my target is a Limit order, I can drag/modify it as always.)
The "refusal to modify" doesn't cause an entry into the Log or TSL.
Is there something I missed about MIT behavior?
Thanks,
Dale
[2017-02-02 17:49:59]
What Trading service is this happening with?
What is the Status of that MIT Target order? You can see it in Trade >> Trade Orders and Positions>> Orders?
Almost certainly there is not anything we can do about this and this is a limitation with the Trading service you are using.
Although it might help to disable this option:
http://www.sierrachart.com/index.php?page=doc/GlobalTradeSettings.html#UseServerSideOCO
Date Time Of Last Edit: 2017-02-02 17:50:26
[2017-02-02 18:06:31]
Trading Service is GainFutures (sim in this case)
Status is Open
Disabling "Use Server Side OCO and Bracket Orders did not help.
The functionality works okay on a Sim account.
I'll contact Gain about this.
Thanks.
[2017-02-02 18:29:07]
We figured this was the case. You will need to contact Gain Capital about this.
[2020-06-15 11:21:23]
User857051 - Posts: 10
You cannot use a server-based Market if Touched order. Instead it needs to be client-side:
Order Types: Market if Touched - Client
Order Rejection Problem
