Date/Time: Sun, 12 Jan 2025 09:51:52 +0000
Automatically adjust candlesticks to fit in the windows.
View Count: 820
[2017-02-02 15:02:27] |
User252419 - Posts: 235 |
How can I automatically adjust candlesticks in order to fit them well in the chart? Thank you |
[2017-02-02 18:25:38] |
We do not understand the question. You are also presenting a high support load to us.
[2017-02-14 18:42:45] |
Is there any Autoescale charts shortcut or option? Thank you and sorry for the load |
