Date/Time: Sun, 12 Jan 2025 04:09:48 +0000
LMAX Trading on Sierra Charts OLD spreadsheets
View Count: 670
[2017-02-01 23:30:28] |
JordiE - Posts: 38 |
Hi, Support Team, good evening, I wish and hope you're fine. I'd like to know if is it possible to open a LMAX trading account by using Sierra Charts Version 1307, OLD spreadsheets, because I did a lot of programming since long time ago on it. Best regards and many thanks in advance for your reply. Jordi |
[2017-02-01 23:51:58] |
Hi again Support Team ! What about OPTIMUS-FX, is it possible to trade Forex on this Broker using SC version 1307 OLD Spreadsheets ? Thanks so much, in advance, for your reply Best regards Jordi |
[2017-02-02 03:37:58] |
You really need to use the latest version for cash Forex trading unless you are using Sierra Chart with Interactive Brokers. We still remember that we have a spreadsheet that we need to convert for you. It is just very large and we have not had chance to work on that yet. We are also not sure we would be successful converting it because of its size. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-02-02 08:44:15] |
Hi, Support Team, thank you for your quick reply. Yes, I'm aware it's stilll pending on your side. I was just wondering about possible alternatives, just in case it would not be possible a succesful converting to NEW spreadsheets model. The one you already did, it was not succesfully converted, because of large number of formulas much more than just the cells officially dedicated to. I still did not mention it to you, because I was waiting for the one you have on hands. Thanks for all your support. Have a nice day ! Regards Jordi |
