Date/Time: Sun, 12 Jan 2025 04:04:37 +0000
Version 1512 Prerelease | VWAP not working correctly
View Count: 772
[2017-02-01 08:49:29] |
User10875 - Posts: 42 |
Having updated Sierra Chart to version 1512, the VWPAP indicator is just tracking the Last price. Pushing the apply button under Chart studies recalculates the VWAP correctly but as soon as a new trade comes in the VWAP line just jumps to the last price. I can install the previous version, but would like to keep the current version. Thanks. |
[2017-02-01 09:20:49] |
This has been solved in version 1513.
