Date/Time: Sun, 12 Jan 2025 04:23:20 +0000
[Programming Help] - request for sample code to
View Count: 803
[2017-02-01 03:11:26] |
User312636 - Posts: 7 |
I would like to build a system (c++) which uses both parabolic sar and heiken-ashi smoothed. can you provide a sample code that show both of them use in the same study(strategy) , and not separate studies ? I would also like to query the value of the parabolic sar and the value of the heiken-ashi smooth open and current , thanks for you help in advance. |
[2017-02-01 03:53:31] |
The only help we can provide with this is refer you to the sc.Parabolic function: sc.Parabolic() If you have the Heikin-Ashi Smoothed study added to the chart you can refer to its data by following the method documented here: ACSIL Programming Concepts: Using or Referencing Study/Indicator Data in an ACSIL Function Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
