Date/Time: Sun, 13 Sep 2026 11:56:18 +0000
c++ code to Query for active trade entry direction
View Count: 1264
| [2017-02-01 02:58:21] |
| User312636 - Posts: 7 |
Can you please provide c++ sample code showing how I can query the chart to know if I am in a long or short position?
| [2017-02-01 03:56:48] |
Refer to: Automated Trading From an Advanced Custom Study: Getting Trade Position Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2017-02-06 15:04:04] |
Hi, I am trying to use your HeikinAshiSmoothed acsil and having a hard time, can you please provide instructions on how to access the HASMOOTH OPEN / CLOSE values? I copied your: SCSFExport scsf_HeikinAshiSmoothed(SCStudyInterfaceRef sc) and pasted it in my study, now what is the next thing I need to do, can you please provide code sample instead of brief answer, because I've been searching all over your site and keep seeing postings that say to paste the scsf_HeikenashiSmoothed in the study, but can't seem to figure out how to get the values from it. Please help , with code explanation ? I would appreciate it, thank you very much . |
| [2017-02-06 18:06:30] |
Did you enable the Display as Main Price Graph option for the Heikin-Ashi Smoothed study?: http://www.sierrachart.com/index.php?page=doc/ChartStudies.html#DisplayAsMainPriceGraph I copied your: SCSFExport scsf_HeikinAshiSmoothed(SCStudyInterfaceRef sc) and pasted it in my study, now what is the next thing I need to do, can you please provide code sample instead of brief answer, because I've been searching all over your site and keep seeing postings that say to paste the scsf_HeikenashiSmoothed in the study, but can't seem to figure out how to get the values from it. Please help , with code explanation ? This is generally outside the scope of our support to provide this level of programming help. Also, there is no official information from us that says "keep seeing postings that say to paste the scsf_HeikenashiSmoothed in the study,". The method you should use is documented here: http://www.sierrachart.com/index.php?page=doc/ACSILProgrammingConcepts.html#UsingStudyData Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-02-06 18:07:51
