Date/Time: Sun, 12 Jan 2025 04:12:25 +0000
Two different stops
View Count: 613
[2017-01-31 20:32:11] |
User26753 - Posts: 43 |
I Need your help to auomatiza the following stop strategy. I trade the CL and I use a fixed stop of 10 ticks When the price goes 6 ticks in my favour I want to move my stop 6 ticks in my favour. When the price goes 10 ticks in my favour I move my stop loss to breakeven, but I know how to do it with the "offset in ticks Triggered. I need helo for the first movement to 6 ticks, if it is possible. Thank you in advance |
[2017-02-01 21:13:03] |
We apologize for the delay. Yes this can be done. We will put together a Trade Window configuration file later today for this.
[2017-02-01 22:34:38] |
Attached is the Trade Window configuration file that does what you require. Here are the instructions to use it: http://www.sierrachart.com/index.php?page=doc/TradeWindow.html#ConfigurationFileAnotherSource Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-02-01 22:34:48
Two-Step Move to Breakeven.twconfig - Attached On 2017-02-01 22:32:21 UTC - Size: 6.18 KB - 327 views |
