Date/Time: Sun, 12 Jan 2025 04:06:14 +0000
: Array is unallocated. | 2017-01-30 17:57:00 *
View Count: 729
[2017-01-31 17:38:22]
User104817 - Posts: 4
I keep receiving on chart startup. Does anyone know how to resolve this?
[2017-01-31 22:29:07]
We will need to get your Chartbook to test this and see what the problem is. Follow the instructions here to provide that:
https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile
[2017-01-31 23:13:00]
File attached
Date Time Of Last Edit: 2017-02-01 01:20:01
[2017-02-01 01:19:10]
At least one of the problems is that you are using the Subgraph Draw Style: CUSTOM_VALUE_AT_Y when it should not be used.
Make sure you are not using this with any study Subgraph unless you know it should be used. Here are the instructions to access the Subgraphs tab for each study:
Chart Studies: Subgraphs Tab
Date Time Of Last Edit: 2017-02-01 01:19:23
