Date/Time: Sun, 12 Jan 2025 03:58:44 +0000
spontaneous scrolling position
View Count: 835
[2017-01-31 12:44:32] |
User514370 - Posts: 62 |
I have couple of tabs in chartbook. And I am switching among them, very often position in the tabs are moved to the history. I have to manually move position to the current one. Why this happens? It´s really annoying. Thank you! |
[2017-01-31 16:16:55] |
Refer to this section here about why this kind of problem occurs and the solution: Working With Charts: Automatic Scrolling as New Bars are Added Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
