Date/Time: Sun, 12 Jan 2025 05:35:23 +0000
relative volume
View Count: 1303
[2017-01-31 11:52:17] |
User713850 - Posts: 33 |
the relative volume study is set to >=5 currently in sierra. If i wanted to look at the relative volume for a current 15 or 5 minute timeframe relative to the average 20 24 hour sessions during that timeframe, what would the setting need to be adjusted to? THnaks. |
[2017-01-31 17:00:31] |
Adjust the Period-Days to Include Relative Volume study Input to 20.
[2017-02-02 11:08:02] |
How do i adjust the period-days to include relative volume study input to 20? Does this mean just change the lookback period to 20?
[2017-02-02 18:09:55] |
Is this a question about how to change study Inputs? Here is the documentation for that: http://www.sierrachart.com/index.php?page=doc/ChartStudies.html#AddingModifyingStudies Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-02-02 18:10:27
[2017-02-03 12:49:01] |
its a question pertaining to what the automated setting attached to this email is actually basing relative volume off of. Is this based upon the relative volume of the last 5 bars or 5 days for that session timeframe? If days then all i need to do is change the input setting to 20 obvsiously. If 5 periods then i need to know how to switch the setting to days. I am confused as to where "period days to include" is even located on the settings and inputs tab.
Capture.PNG / V - Attached On 2017-02-03 12:47:18 UTC - Size: 24.06 KB - 254 views |
[2017-02-03 18:02:17] |
You are using the wrong Relative Volume study. That is a user contributed study. It was not developed by Sierra Chart. Do not use that study. You need to use this study which is also called Relative Volume: https://www.sierrachart.com/index.php?page=doc/TechnicalStudiesReference.html#s356 You will see it directly listed in Analysis >> Studies. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-02-04 15:05:23] |
well that explains it. cheers.
