Date/Time: Sun, 12 Jan 2025 04:04:37 +0000
Adjust Copied Chart Drawings
View Count: 1202
[2017-01-31 10:51:37] |
User471008 - Posts: 2 |
Hello, I have two charts with the same symbol, different timeframe. On the higher TF chart I draw a horizontal line, use 'Copy Chart Drawings from Chart #'s' to display it on the lower TF chart. I'd like to adjust the horizontal line on the lower TF chart, but can't. Is there any way to move a chart drawings if its copied from an other chart? If not, is there any other method to alter or copy drawings from one chart to another and can 'modify' them other then the source chart? Thanks. |
[2017-01-31 16:41:47] |
This is not currently supported but we expect will be in about two months.
[2017-02-01 08:34:22] |
Ok, copy that. Thanks. |
