Date/Time: Sun, 12 Jan 2025 03:56:49 +0000
Two instances
View Count: 862
[2017-01-31 07:09:37] |
nicktrader - Posts: 727 |
I am running two instances with two different datafeeds. In most cases I am using the same charts on both instances. Each morning I am preparing the charts in one instance with all needed drawings. I also want the same prepared charts in the second instance. What is the best and easiest to do that. Because of the two different datafeeds the symbols are different too. Is there a way (maybe) in the "Symbol Settings" to set the symbol from the other datafeed that I could copy the chartbook only from one instance to the second (just an idea)? |
[2017-01-31 16:11:01] |
You will want to copy the Chartbook from one instance over to the other instance. Refer to: https://www.sierrachart.com/index.php?page=doc/Chartbooks.html#CopyChartbook Because of the two different datafeeds the symbols are different too. Is there a way (maybe) in the "Symbol Settings" to set the symbol from the other datafeed that I could copy the chartbook only from one instance to the second (just an idea)?
This is a problem. We do not know of a solution other than to manually change the symbols:Changing the Symbol of a Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
