Date/Time: Sun, 12 Jan 2025 04:26:08 +0000
VWAP in Version 1510
View Count: 998
[2017-01-31 01:55:57] |
User150371 - Posts: 70 |
In version 1510 I cannot get the VWAP to draw properly when using Start Date- Time eg 2017-01-30 08:00:00. I tried version 1512 and had the same problem. I re-installed version 1500 and the VWAP draws properly there. |
[2017-01-31 08:37:33] |
We are looking into this.
