Date/Time: Sun, 12 Jan 2025 04:21:42 +0000
ACS - put/draw images on chart
View Count: 799
[2017-01-30 22:55:54] |
jizzary - Posts: 177 |
i'm looking to put images (like arrow) on chart in reference w/ certain bar / candle can u pls refer me to a code example to see how to - select a figure - set its color - set its location in reference w/ specific bar - how to put it the image, hide it and delete it from chart tnx |
[2017-01-31 02:39:12] |
This can be done by using Marker drawings. Refer to: Using Drawing Tools From an Advanced Custom Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
