Date/Time: Sun, 12 Jan 2025 04:12:00 +0000
Different Values of SMA on different computers
View Count: 732
[2017-01-30 17:44:25] |
User587108 - Posts: 1 |
Hi everyone, I apply SMA to an indicator and on different computers (at the same time) it gives values differing around 4 times:/ What can be a reason for it? I've already checked the chart options, connection options and the indicators options. They seem to be same:/ The versions of Sierra are same. Has anybody faced such problem? How to solve it? Any ideas? Best regards, Artur Date Time Of Last Edit: 2017-01-30 19:27:34
[2017-01-30 19:32:53] |
Make sure the Chart >> Chart Settings are exactly the same between the two different copies of Sierra Chart. We know that you said you checked these. But check them again. If you continue to notice a problem post an image of both charts where you see the difference, by following the instructions here: https://www.sierrachart.com/index.php?page=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
