Date/Time: Sun, 12 Jan 2025 04:04:45 +0000
No Study Function Present
View Count: 836
[2017-01-30 15:43:50]
JRA - Posts: 97
I used to use a contributed study, but after the last updates (don't rembmer from when since last time I was using it was 6 months ago) it gives the following message that I am attaching as a screenshot.
imageNoStudyFunctionPresent.png / V - Attached On 2017-01-30 15:43:28 UTC - Size: 22.12 KB - 281 views
[2017-01-30 19:46:52]
This problem has been solved in the latest pre-release.
But there is currently a historical data downloading issue in sub instances with the prerelease that we are solving. We need about another 2 to 3 hours.
You can update now if you are not using File >> New Instance.
Here are instructions to update to the pre-release:
http://www.sierrachart.com/index.php?page=doc/download.php#FastUpdate
Date Time Of Last Edit: 2017-01-30 19:47:15
[2017-01-31 00:32:47]
It is fine to update to the latest prerelease now.
