Date/Time: Sun, 12 Jan 2025 04:19:48 +0000
free memory
View Count: 748
[2017-01-30 13:29:25] |
User20450 - Posts: 330 |
woke up to this message when tried to hit help button , and also on log for the bid ask depth bars - any solution ?
2017-01-30_08-27(2).jpg / V - Attached On 2017-01-30 13:29:00 UTC - Size: 14.55 KB - 265 views 2017-01-30_08-27.jpg / V - Attached On 2017-01-30 13:29:05 UTC - Size: 18.21 KB - 257 views |
[2017-01-30 20:02:54] |
Refer to this section here: http://www.sierrachart.com/index.php?page=doc/WorkingWithCharts.html#OutOfMemoryCondition Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-01-31 02:45:28] |
ok , i have tried new instance but it creates my org instance to just keep reconnecting so i gave up on it
[2017-01-31 03:07:54] |
What you are describing in the last post does not make sense why there would be any problem with that. We have no other reports of this. We also have no details about it either. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-01-31 03:13:11] |
ok im just telling you what happens when i open a new instance , im not trying to waste your or my time . i just wont use it then
