Date/Time: Sun, 12 Jan 2025 04:13:51 +0000
MDI on Detached Chart
View Count: 813
[2017-01-30 04:27:14] |
User488039 - Posts: 114 |
I know I can have MDI tabs at the bottom of the main chart. Is there a way to have MDI tabs at the bottom of a detached stand alone chart? Thanks |
[2017-01-30 04:29:09] |
No. This is not supported.
