Date/Time: Sun, 12 Jan 2025 04:18:56 +0000
hello
View Count: 637
[2017-01-28 09:05:30] |
User166767 - Posts: 32 |
hello ,which exchange the dollar index data in the sierra chart is from?I find It has a little difference with Fxstreet dollar index?can you tell the reason?please see the screenshot.
QQ截图20170128030204.png / V - Attached On 2017-01-28 09:04:21 UTC - Size: 42.72 KB - 224 views |
[2017-01-28 09:35:46] |
The USDX dollar index provided by Sierra Chart is calculated by Sierra Chart using the FXCM Forex data feed.
