Date/Time: Sun, 12 Jan 2025 04:10:10 +0000
Update SC header files when sub-instance of SC is upgraded
View Count: 643
[2017-01-27 22:41:18] |
Al SC Developer - Posts: 434 |
When a sub-instance of SC is automatically upgraded after the main instance is updated, the SC provided header files should also be upgraded in the sub-instance ACS_Source directory. Currently, the files become stale because they are not updated.
[2017-01-27 22:56:01] |
OK we will do that.
