Date/Time: Sun, 12 Jan 2025 04:02:23 +0000
question about sc.ArraySize
View Count: 731
[2017-01-27 19:46:30] |
User103949 - Posts: 78 |
I noticed my sc.ArraySize was around 45000 at 19:50 at night. I am setting my chart at 1 tick level. According to my previous post and answers from SC, sc.ArraySize should always increase, but after one day of running my study without stopping, there was no way that the sc.ArraySize is only 45000. I could not monitor my study during session close time, which was between 16:00 and 17:00. So my only conclusion was sc.ArraySize is related to how many days to load( I set 1 in the chart setting) and when is the session start and end time. |
[2017-01-29 01:01:17] |
sc.ArraySize will always increase as bars are added to the chart, unless the chart is reloaded. What you need to do is scroll back to the very first bar in the chart and make a note of the Date-Time and later see if that Date-Time is not there. If not, this indicates the chart was reloaded and the data in the chart is reduced because of the reasons explained here: https://www.sierrachart.com/index.php?page=doc/ChartSettings.html#DaysToLoad Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2017-01-29 18:48:56
