Date/Time: Sun, 12 Jan 2025 04:01:48 +0000
Mouse click to bar index
View Count: 900
[2017-01-27 18:55:30] |
flyboy615 - Posts: 56 |
Is there a way to convert a mouse event, say mouse up, to a bar index that corresponds to the position of the cursor at the time of the event? Thanks |
[2017-01-29 00:52:04] |
Yes. Refer to: ACSIL Interface Members - Variables and Arrays: sc.ActiveToolIndex Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
