Date/Time: Sun, 12 Jan 2025 04:10:34 +0000
How to Open the Old Copy SC after Installing New Copy
View Count: 706
[2017-01-27 18:32:21]
User268363 - Posts: 10
Hi there, I installed a second copy of Sierra chart on the same computer to a different folder, but after installation I couldn't figure out how to open the old copy of SC. I can see the old and new folder for the two copies, but When I click on the desktop icon it always opens the new copy. When i use the start menu, and click SC from the most used app list, it also opens the new copy. Could you tell me how can I open the old copy of sierra chart please? Much appreciated!
[2017-01-27 18:55:17]
You just need to go to the installation folder of the old Sierra Chart copy and then run the file SierraChart.exe.
You can create a shortcut to this executable and put it on your system desktop.
