Date/Time: Sun, 12 Jan 2025 04:08:48 +0000
Real Time Data
View Count: 921
[2017-01-27 18:23:37] |
User87521 - Posts: 116 |
I have been reading through your Service Packages and cannot seem to find an answer to this. I am looking at getting real time data for certain market internal symbols. (UDVR-NYSE, ADR-NYSE for example) Is there a service package where this will occur in real time, or is the data offered always delayed?
[2017-01-27 18:48:56] |
Real-time data for the symbols is provided with the Sierra Chart Market Statistics Data Feed which your Sierra Chart package includes. Refer to the instructions here: http://www.sierrachart.com/index.php?page=doc/SCMarketStatistics.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-01-27 19:20:03] |
OK, thank you. I guess I was thrown off by the fact that my Study/Price Overlay is displaying the same data for last 5 bars in a row in my main chart. It displays correctly in the source overlay chart. I'm not really sure why its doing this as the chart timeframes are all set at 15 min. and the chart Session Times are the same. Either way, as long as the Last data item displayed is real time that's all I need. Thanks again. This is truly a great piece of software you have developed. |
