Date/Time: Sun, 12 Jan 2025 04:02:37 +0000
Volume Histogram
View Count: 1349
[2017-01-27 01:32:44] |
User713850 - Posts: 33 |
Hello, How do i get my chart which is renko based to show a histogram/prof with ask-bid vol imbalance similar to the picture attached to this post? The link below shows where i am at currently which only shows bid-ask vol imbalance (diagonally) http://www.sierrachart.com/image.php?Image=1485480644158.png Thanks. |
Capture.PNG / V - Attached On 2017-01-27 01:26:12 UTC - Size: 63.91 KB - 245 views |
[2017-01-27 18:53:22] |
You need to set the Column 1 Background Type Input to : Ask/Bid Volume Split Profile Refer to: http://www.sierrachart.com/index.php?page=doc/NumbersBars.php#BackgroundTypes Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
