Date/Time: Sun, 12 Jan 2025 01:47:23 +0000
can't upgrade
View Count: 683
[2017-01-26 07:17:07]
user14348 - Posts: 5
Hey,
I try to upgrade my software and i received this message,
Notice:Service package 5 (Advanced) will only be allowed to be used on two systems at a time after the usage time is renewed on your account instead of previously 3 systems. For additional systems, go to the Services Activation page to activate additional systems.-Version 1510 is available. To download, select Help >> Download Current Version.
At this moment the software was installed on 3 computer, and i never used more than 2 at the same time, and today only one
what i can do
regards
[2017-01-26 08:08:41]
Disregard this message. It does not apply in your case. You can install Sierra Chart on as many systems as you want. The message only indicates that you cannot use it on more than two systems at the same time after renewing the usage time unless you pay for additional systems.
You can safely update. There is no problem with this.
