Date/Time: Sun, 12 Jan 2025 04:02:47 +0000
Shortcut to change fast the Input Value of Market Depth Historical Graph: Quantities >= to
View Count: 970
[2017-01-26 01:02:20]
User252419 - Posts: 235
Is there any shortcut or button to fastly change the Input Value called Graph Only Quantities Greater or Equal to: INPUT VALUE? The Input value in Market Depth Historical Graph.
Thank u
Date Time Of Last Edit: 2017-01-26 01:02:50
[2017-01-28 06:03:53]
Update to the latest prerelease and refer to the documentation here:
Chart Studies: Changing Study Inputs Directly from Chart
[2017-01-29 17:37:58]
I have version: 1510
I only have 1 study in the chart: 1.Market Depth Historical Graph.ID:1 and I want to modify Graph Only Quantities Greater Or Equal to.
To modify this from the keyboard I try to write this:
In:Id1.In4=xxxx
But I can not write any digit xxxx. It gets stuck here: In:Id2.In1= and I can not write any number.
What should I do?
Thank you
[2017-01-29 17:50:03]
This does not make sense. The only logical conclusion is that the title bar no longer has any space to show the additional characters but certainly they are getting captured.
There is nothing you need to do. Just trust that the numbers are actually getting entered and press the Enter key.
[2017-01-29 21:08:18]
I have detached the window and now I see the numbers while I write but nothing changes when I click enter. Do I need to write something in Study Settings:Market Depth Historical Graph: Graph Only Quantities Greater or Equal To: XXX?
Thank you
[2017-01-29 22:55:45]
You did not follow the documentation and determine what the correct Input number is.
You need to enter
In:Id1.In8=[value]
Date Time Of Last Edit: 2017-01-29 22:56:03
[2017-01-29 23:47:39]
Still not working. I click enter and nothing happens.
http://www.sierrachart.com/image.php?Image=1485733579500.png
I am in ES contract writing this in a chart with a single study:
In:Id1.In8=1500 and then clicking enter.
I don't have clear in the documentation which number should I write with that picture in: In:Id1.InX However I am writing this now In:Id1.In8=1500 as you said in the last message.
Date Time Of Last Edit: 2017-01-29 23:50:50
[2017-01-29 23:51:46]
You did not update to the latest prerelease. You need to update the prerelease 1511.
[2017-01-30 00:05:41]
To update you need to use Help >> Download Prerelease.
However, please wait about 15 minutes because we are releasing a new prerelease.
There is a problem where an exception would occur that we are solving that might have got released to the current Prerelease.
Date Time Of Last Edit: 2017-01-30 00:07:50
[2017-01-30 00:08:09]
The new revision is now out. Update with Help >> Download Prerelease.
