Date/Time: Sun, 12 Jan 2025 01:42:20 +0000
ACS - reading other study's Subgraph[].Data[X]
View Count: 675
[2017-01-25 22:42:33] |
jizzary - Posts: 177 |
i'm looking to read specific entry X : Subgraph[].Data[X] for performance considerations i would like to avoid re-reading the whole array every time i need to read a one (or very few) new values i assume otheres raised this issue and there is a ready for use solution. can u pls direct me to it (documentation/code example) tnx |
[2017-01-26 03:45:31] |
We are not clearly understanding this. Just simply read the the array elements you need to read and it will be very fast.
