Date/Time: Sun, 12 Jan 2025 01:54:55 +0000
order timestamp doesn't match the bar timestamp
View Count: 737
[2017-01-25 22:37:23] |
onnb - Posts: 662 |
hi - in sim mode, I have a situation like this Order is submitted at the close of the bar - say sc.Index for this bar is 100 The timestamp of the new bar (index 101) is 9:48:06. The EntryDateTime of the order is 9:48:04 Usually we see that EntryDateTime is after bar 101's timestamp. So when calling GetContainingIndexForSCDateTime(EntryDateTime), it returns index 100 - I was expecting to get 101. Hope I am making sense - if not let me know. |
[2017-01-26 04:13:14] |
Refer to the description for the Entry Time field here: Trading Information Windows: Order Window Field Descriptions That should answer the question. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
