Date/Time: Sun, 12 Jan 2025 00:42:41 +0000
[Programming Help] - ACS - sc.UseGlobalChartColors
View Count: 690
[2017-01-25 16:04:28]
jizzary - Posts: 177
the below is unclear (pls don't answer bt referring me to the web page)
need some explanation (soem short example will assist)
[Link] - [Top]
Type: Read/Write Integer variable.
When sc.UseGlobalChartColors is set to 1 or a nonzero number, then the global color settings defined in Global Settings >> Graphics Settings are used for the chart.
When sc.UseGlobalChartColors is set to 0, then the chart specific color settings defined in Chart >> Graphics Settings are used for the chart.
Since sc.UseGlobalChartColors affects the chart itself, it must be located outside and below the sc.SetDefaults code block.
Example
