Date/Time: Thu, 19 Sep 2024 01:05:20 +0000
Help with indicator
View Count: 1500
[2013-08-08 14:01:56] |
User75564 - Posts: 42 |
I currently use CCI with 2 "Color bar based on alert condition". 1.Arrow Up & 2.Arrow down I was wondering if I can put a 15 min CCI on a 5 min Chart. Thanks. |
[2013-08-08 16:24:40] |
Yes. Refer to help topic 28 here: Http://www.sierrachart.com/index.php?l=doc/helpdetails28.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
