Date/Time: Thu, 17 Sep 2026 16:09:54 +0000
Cannot add new inputs to an already created study
View Count: 1170
| [2017-01-25 15:43:29] |
| AcquaLife - Posts: 33 |
I am a little confused why I can never add additional inputs to an already built study. I have sc.FreeDLL = 1 and I am trying to add the input SCInputRef Study1 = sc.Input[5]; // I change it from input 0 to 5 since i already have an input 0 SCInputRef Study1Subgraph = sc.Input[6]; // I change it from input 1 to 6 since i alrady have an input 1 This is from the referencing other time frames documentation. Additionally, I put this in my default code block Average.Name = "Average";
I also define Average as described in the code example.Average.DrawStyle = DRAWSTYLE_LINE; Study1.Name = "Input Study 1"; Study1.SetStudyID(0); Study1Subgraph.Name = "Study 1 Subgraph"; Study1Subgraph.SetSubgraphIndex(0); Furthermore, I am sure that I am not assigning the input somewhere else, i.e i only assign input 5 and 6 in those two lines. Basically, I want to do price overlay study to pre-existing code. But since I can not get these inputs to show up in the setting of the study, so I can not define which study to look at. Please help. Thanks |
| [2017-01-25 17:53:59] |
When you are adding or removing Study Inputs, you most definitely need to remove the study from the chart and add it again. Or close and reopen the Chartbook it is contained within.
