Date/Time: Sun, 12 Jan 2025 01:55:38 +0000
Coloring TPO letters above and below value area highlighting
View Count: 974
[2017-01-25 14:50:56] |
BenjaminR - Posts: 170 |
I'd like to color the letters above and below the highlighted Value Area similarly to the auto-coloring of slope or +/- in the Subgraphs section of studies. Are there coloring options that respect the Value Area? In this case, I'm looking for the letters above the VA to be red, and the letters below the VA to be blue... (Attached is an image, absent coloring the TPOs below the VA blue.) Thank you, Ben |
[2017-01-25 17:55:13] |
No, this is not supported.
