Date/Time: Sun, 12 Jan 2025 01:40:56 +0000
Limited number of monthly bars in Historical Chart
View Count: 660
[2017-01-25 14:39:42] |
BenjaminR - Posts: 170 |
I am having trouble displaying more than 14 monthly bars, which remain to the left side of chart. (I'd like to see up to 5 years, but at least 2 years.) I've tried changing the Date Range settings various ways unsuccessfully, searched the contents pages, and the support board for similar problems, to no avail. I've checked to see if there was another contract symbol I needed to use, but I'm not sure. I'm using Rithmic data in this case. Attached is a chart image, and image of chart settings. Please advise... Thank you, Ben |
ES Monthly Chart image.PNG / V - Attached On 2017-01-25 14:37:43 UTC - Size: 38.27 KB - 244 views ES Monthly Chart Settings.PNG / V - Attached On 2017-01-25 14:37:50 UTC - Size: 47.99 KB - 228 views |
[2017-01-25 17:49:22] |
You need to use the Continuous Futures Contract feature: http://www.sierrachart.com/index.php?page=doc/ContinuousFuturesContractCharts.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
