Date/Time: Sun, 12 Jan 2025 01:45:22 +0000
Reset DOM Recent Bid/Ask Volume
View Count: 2948
[2017-01-25 11:17:00] |
User252419 - Posts: 235 |
Is it possible to reset Recent Bid/Ask Volume (in DOM) in order to clear previous Recent Bid/Ask Volume when I want, and start seeing the new Recent Bid/Ask from the time I reset it? Thank you |
[2017-01-25 18:02:17] |
Yes. This is documented here: http://www.sierrachart.com/index.php?page=doc/GlobalTradeSettings.html#ResettingResettableTradeChartDOMColumns Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
