Date/Time: Sun, 12 Jan 2025 01:47:23 +0000
Where to find reference for variable's description?
View Count: 857
[2017-01-25 04:44:21] |
User701247 - Posts: 117 |
I would like to know on where to find reference for variable's description, in order to understand their meaning. Furthermore, I would like to know on what following symbol represents on coding too -> && Does anyone have any suggestions? Thanks in advance for any suggestions Example for variables !sc.VolumeAtPriceForBars->GetVAPElementAtIndex(BarIndex, PriceIndex, &p_VolumeAtPrice) p_VolumeAtPrice->PriceInTicks * sc.TickSize AskVolumeBidVolumeDifference < 0 && VolumeThresholdSigned < 0 && AskVolumeBidVolumeDifference <= VolumeThresholdSigned Date Time Of Last Edit: 2017-01-25 05:01:38
[2017-01-25 05:02:50] |
The documentation that is available is here: ACSIL Interface Members - Introduction Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2017-01-25 05:45:20] |
Thank you very much for suggestions :>
[2017-01-25 07:17:27] |
I can find reference for VolumeAtPriceForBars, not GetNumberOfBars(), and would like to know on what symbol "->" represent and where to find any reference for available function such as GetNumberOfBars(). Do you have any suggestions? Thanks in advance for any suggestions (int)sc.VolumeAtPriceForBars->GetNumberOfBars() Date Time Of Last Edit: 2017-01-25 14:46:44
[2017-01-26 05:29:36] |
The member functions for sc.VolumeAtPriceForBars are not currently documented but we will gradually work on those. We will start with this one. We have updated the documentation here including the answer to your other question: ACSIL Interface Members - Variables and Arrays: sc.VolumeAtPriceForBars Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
